It is currently Sat Feb 24, 2018 5:38 am
 Page 1 of 1 [ 3 posts ]
 Post subject: One more boring review about LED lights...Ct lite G4 150w LE
PostPosted: Mon Aug 03, 2015 3:12 pm
Marine Bacteria
Marine Bacteria
User Reviews/Tips/DIY
Reviews, tips and DIY articles submitted by site members on products they have evaluated and tested (NZMAS Members only)
So I placed it DIY
To be clear - I have no affiliation with this brand, I am a hobbyist like everyone else.
My tank needed a lights upgrade and after using KAY and Maxspect Led lights, I decided to give the Ct lite G4 150w LED lights a go. Right now, I’m very impressed with these lights. I would easily compare their standard with that of Maxspect (casing and light colors)
The lights have a very good control system, that I personally enjoy. You can see the control system at work, below:
http://www.youtube.com/watch?v=8dEqtqePMHE
I started using the lights on the 22.05.2015 and today the date is 03.08.2015 and I have no regrets! My corals have been responding great, the tank looks good; what else do I need?
 Post subject: Re: One more boring review about LED lights...Ct lite G4 150
PostPosted: Mon Aug 03, 2015 3:14 pm
Marine Bacteria
Marine Bacteria
1. Waterproof and Low DC input:
- Front side: IP66
- Rear side: IP54
- Safe 48V DC input with UL certificated power module
2. Full aluminum housing:
- Small dimension: 24cm x 22cm x 3cm
- Super thin (3cm thickness only)
- Super light (1.76kg /module), cost saving for delivery
- Super heat dissipation and long life time
- Anti-rust / corrosion
3. Five LED channels:
- Ch1: AquaBlue
- Ch2: AquaWhite
- Ch3: AquaPurple
- Ch4: AquaUV
- Ch5: AquaSpecial
- Provides 10,000,000,000 (100*100*100*100*100) colors
4. Intelligent Control:
- APP control
- Truly Intelligent LED Aquarium Light with APP control
- Easy programming for each LED channel at each hour of a day
- Super high spectrum efficiency
- Higher energy efficiency
Item Description Item Description
Model Number CTL--G4-MAM-150 Power draw 64x3W leds
Light channels AquaBlue/ AquaWhite/ AquaPurple/AquaUV/AquaSpecial Beam angle(COB) 90 degree-100 degree
LED quantity 64*3W LEDs Beam angle(LED) 60 degree -70 degree
DC input  DC 48V Control method IOS/Android mobile control
Standby consumption 2W Power consumption  150W±5%
Spectrum full spectrum Waterproof level Front:IP65,Rear:IP54
Control transmission WIfi and RF Power Efficiency >85%
Working humidity Less than 95% Temp Arise Heat Sink-air <20 degree
Housing material Aluminum Storage termperature -20℃ to 60℃
Life span 5 years Working temperature 0℃ -45℃
Product size 240mm(L)*220mm(W)*30mm(H) Net weight 1.76kg
Package Dimension 380mm(L)*280mm(W)*140mm(H) Gross weight 2.16 KG
PostPosted: Mon Aug 03, 2015 3:40 pm
Marine Bacteria
Marine Bacteria
Photos:
https://www.dropbox.com/s/l3prjslekxbcy ... 2.jpg?dl=0
https://www.dropbox.com/s/0do17dqd77piv ... 8.jpg?dl=0
https://www.dropbox.com/s/5z3x58v9l6ndu ... 3.jpg?dl=0
https://www.dropbox.com/s/rzuaau6cgb680 ... 1.JPG?dl=0
https://www.dropbox.com/s/lvu3i5wspzvtk ... 1.JPG?dl=0
https://www.dropbox.com/s/wuatpjcqoaup2 ... x.3gp?dl=0
