It is currently Wed Sep 26, 2018 2:04 pm
 Page 1 of 2 [ 21 posts ]  Go to page 1, 2  Next
 Post subject: Led lights. Has anyone have or used Pacific sun leds?
PostPosted: Tue Aug 20, 2013 11:58 pm
Picoplankton
Picoplankton
I know there has been a lot of led light threads. But have been looking through quite a few.
I have an aqua reef 400 and want to change from T5 to LED lighting.
which is 127cm Long x 50cm Wide x 60cm High
So far i have been looking at:
A custom stealth led set up
Maxspect Mazarra P
Pacific sun metis hyperion s2
What i am wanting to know is what brand, model, how long you have been using it for and your results.
 Post subject: Re: Led lights. What are you using?
PostPosted: Wed Aug 21, 2013 11:25 am
Copepod
Copepod
I've got two AI Vegas over my tank , 120x60x60 , Still early days , but the Zoas and acans have responded well to them . I think they are good value and time will tell how my SPS do under them .
I got them from Reefsmart .
PostPosted: Wed Aug 21, 2013 1:59 pm
Protozoa
Protozoa
I use 1x Maxspect RAZOR, but my tanks only 1m wide, so it's perfect. I do love the colours and growth is good, so can't complain.
Given the options available now, I would probably go with AI Vega's if I were to rebuild my tank or do something bigger.
I would stay away from cheap Chinese units and/or custom builds unless you know what you're doing and have done a shitload of research.
Plumber + Electrician + Chemist + Biologist + Environmentalist = Reefer.
PostPosted: Wed Aug 21, 2013 2:04 pm
Copepod
Copepod
Ive just bought Brendon's Maxspect G2's
looking at his build thread he has had massive success with them so i can only hope to have similar results
PostPosted: Wed Aug 21, 2013 6:43 pm
Picoplankton
Picoplankton
Same here. Dont have any corals yet bit they deffently look the part. Bit of disco but if you can handle that for 700 each you cant complain.
Sent from my GT-N7105 using Tapatalk 4
PostPosted: Wed Aug 21, 2013 9:01 pm
Pteropod
Pteropod
2 x Radions over 1400 tank. Love them
There are two types of people in this world:… Those who can extrapolate from incomplete data.
PostPosted: Wed Aug 21, 2013 9:21 pm
Picoplankton
Picoplankton
Did you also get the controller? If so how do you find it?
PostPosted: Wed Aug 21, 2013 10:10 pm
Copepod
Copepod
Got the controller . It is quite small and needs to be plugged in to the USB adapter all the time to provide the control to the lights . I like the features it has in such a small device .
Each light unit it run on a laptop style power supply , so everything is very compact .
The radions are nice , but too expensive for my pocket .
PostPosted: Wed Aug 21, 2013 10:47 pm
Picoplankton
Picoplankton
Thanks for that info. How far above your tank do you have them sitting?
I would be able to afford the radions they are twice the price
PostPosted: Wed Aug 21, 2013 11:19 pm
Copepod
Copepod
They are about 8 to 10 inches above the water .
PostPosted: Wed Aug 21, 2013 11:24 pm
Picoplankton
Picoplankton
I was looking through your thread and i am trying to work out what you used to mount the lights
PostPosted: Wed Aug 21, 2013 11:51 pm
Copepod
Copepod
I used a 25ml aluminium tube mounted on two pieces of wood and then fitted two plastic clips on each light unit that I got from the electrical dept at mitre ten mega .
I screwed some aluminium channel to the two pieces of wood and now I can slide the lights back and fourth on my existing hood .
The lights can also slide up and down on the tube with a little effort , or I can rotate them at an angle .
PostPosted: Thu Aug 22, 2013 7:01 am
Picoplankton
Picoplankton
Do yourself a favour and buy the rail and hanging kit if you get Vegas. Looks very sharp. 1400 in lights and a ugly diy mount doesn't make sense to me, especially if the tanks in the lounge or similar. I'm sure your mount Brendon is the exception ;)
PostPosted: Fri Aug 23, 2013 7:08 pm
Picoplankton
Picoplankton
would anyone know the driver/power supply of the ai vega
PostPosted: Fri Aug 23, 2013 10:08 pm
Picoplankton
Picoplankton
Users browsing this forum: Bing [Bot] and 3 guests
