It is currently Sat Feb 24, 2018 5:31 am
 Page 1 of 1 [ 1 post ]
Author Message
 Post subject: Hydra Aquatics Biopellet reactors
PostPosted: Wed Oct 28, 2015 2:40 pm
Picoplankton
Picoplankton
We are now stocking the Hydra Aquatics Biopellet reactors.
The Hydra Aquatics Biopellet Reactor is a great piece of equipment used to boost biological activity in an aquarium with the use of biopellet media. The reactor works by pushing a stream of water through an accelerator which agitates the media and puts it in motion within the reactor. This process is called fluidization. The efficiency of the media is increased it churns inside the reactor. The filtered water is then returned to your aquarium.
One of the greatest advantages the Hydra Aquatics Biopellet Reactor has over its competitors lies in its innovative design. Hydra Aquatics has solved the two most common problems that plague standard media reactors by incorporating an inverted conical bottom and a top-fed flow accelerator.
Most media reactors use a bottom-fed flow diffusion method through a plate. This smooth, constant flow is typically referred to as up-flow or reverse flow. Unfortunately, using this type of flow inside a media reactor usually causes lighter filter media to clump at the top and denser media to settle at the bottom. Using Hydra Aquatics inverted conical bottom and top-fed flow accelerator design, it is impossible for the media to clump together or settle completely at the bottom.
Using our flow accelerator technology combined with an inverted conical bottom we are able to create specific internal flow patterns. The flow within the reactor keeps media suspended at all times. We guarantee the best water-to-media contact as your media of choice is circulated for 100% full saturation. Flow can easily be controlled using a gate valve or at the pump.
Having proper media saturation and keeping media in suspension will greatly increase contact time of water-to-media. Reactor media that is at a standstill is less efficient as the saturation levels are lowered. With reactor media in full suspension, you are increasing surface area to water contact time which in turn gives you the best results for whatever media you are using. Hydra Aquatics Biopellet Media Reactor is efficiently designed to give you the most out of your choice of media.
FR-30
Recommended Feed Pump: 600-1500 L/H
Media: 50-600ml
Dimensions: Base diameter: 13.75cm Overall Height: 38.75cm.
Inlet Uses 1/2" or 3/4" ID vinyl tubing. (Pump and tubing are not included).
FR-45
Recommended Feed Pump: 1000-2000 L/H
Media: 500-1200ml
Dimensions: Base diameter: 13.75cm Overall Height: 55cm.
Available online: http://www.barkingbuddies.co.nz/index.php?route=product/category&path=20_90_91
_________________
http://www.barkingbuddies.co.nz/index.p ... m_Products
Stockists of AquaMaxx - Caribsea - Kent Marine - Mariscience - New Life Spectrum - Seachem - Two Little Fishies - and more
Offline
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
